7 members (Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl), 138 guests, and 2 robots.
Topics128,114
Posts1,056,283
Members48,439
#1364243 06/10/2020 1:05 AM
I
I Offline
I have a 1950 3600 with an 8 bolt rear end. I'd like it to be a touch faster. I know someone with a 3100 rear end. Are the 1/2 ton rears interchangeable to fit my 3/4 ton?
ASU Offline
The short answer is no, they are not interchangeable. Your truck most likely has an Eaton HO52,HO72 rear axle. Check to see what gear ratio you have, but 4.56 is the fastest As I recall. Look in the 1 ton forum, pinned at the top is A LOT of information about axle swaps for better gears. Most of this info is applicable to 3/4 and 1 tons.
Jon
Crusing in the Passing Lane
4.10 from 3/4 ton w/ auto trans. will work.
Ed
24601
As stated above, most likely your truck still has its original HO52 rear axle. If so, the upgrade to better highway speeds is one of the easiest projects there is for these trucks. Read this Tech Tip Article The info in it applies to the 3600 trucks as well as the 3800 series.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
