| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Hello again, haven't posted in a few years and would like your help: When I parked my 58 spartan 2 years ago, the brakes were working fine, altho the pedal was low and always had been since I rebuilt the entire system 10 years ago. Before pulling the truck out of the shed today I noticed the brake pedal went to the floor - I checked the master cyl and it was empty - yet there were no known prior leaks. Does brake fluid 'evaporate'?, as I can see no evidence of leakage anywhere in the lines or the wheel cylinders. Note that I rebuilt the system completely including resleeving the original 1-1/2" master cyl with new kit and NOS wheel cylinders with modern kits as well as all new lines and hoses....and a remote hydrovac, which was NOS from a 70s/80s era truck. Again, the brakes were functional when last driven. I did notice some possible dried residue on the bottom of the MC, altho not sure what it was, so I removed the MC today and disassembled it and it looks quite clean, just a little rust residue at the push rod end, but no pitting. So, I ask for your ideas, what happened to the brake fluid which was in the master cylinder 2 years ago?
1955 GMC 630, 1959 GMC W660, 1958 Chevy Spartan 80
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jaycoop, I take it by your description that you did not use the same type of Hydrovac that your truck was originally equipped with, so I am not sure if the booster you used has a drain plug that you could remove to see if any brake fluid has accumulated in the booster chamber(s). | | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Thanks for the reply..... no, it's a later type unit, but that is a good thought and you now have me thinking along those lines. I will see if I can figure a way to determine if any fluid was drawn into it.
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | I did find about a tablespoon of brake fluid in the bottom of the vac chamber, so the unit will be coming off for a rebuild.
| | | | | Joined: Apr 2009 Posts: 181 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 181 | Just want to post a sincere THANK YOU to all the experts on this site. After having the remote booster rebuilt by Rebuilders Enterprises in Illinois (recommended by several on this site), rebuilding/replacing the MC and wheel cylinders myself, and taking into consideration all the collective advice and pointers on this site regarding bleeding and adjusting, I now have excellent brakes. Note that this is the second time I went through the brakes (last time about 10-15 years ago) but this time I printed all the pointers from Stovebolt and put them together in a folder and took them out to the shop - and used them in combo with the 58 shop manual. Couldn't have done it without you!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jaycoop, great news, thanks for letting us know! | | |
