4 members (MikeE, Wayne67vert, TexasA&M48Truck, Opelika Tom), 58 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
#1363366 06/03/2020 6:19 PM
So I found a brake master cylinder leak and found two options on rock auto. One is a raybestos the other ACDelco. They each have exactly the same picture, raybestos is 100 and ac delco is 139.
Recommendations?
This is for a 1940 1.5 ton WB.
Sir Searchalot
Sir Searchalot
Least expensive one. Without a doubt. A new rubber seal kit also works. Rockauto RAYBESTOS MK33 $19. Lifetime warranty.
Probably both made off shore anyway. Take the cheaper one
1949 gmc 1-ton
It's most likely the same casting, just a different name on the box. "AC Delco" is an offshore brand now, and has been for several years. "Delco Remy" was a division of General Motors that made electrical parts back in the 50's and 60's, possibly as late as the 1970's. I don't think they ever made brake parts.
Moderator, Electrical Bay
Rebuild it and when you do, hone it carefully and well using brake fluid to lubricate the honing stones. Polish the bore if you are able. That leak will stop unless rust and age have pitted your bore too far. I've seen some that leaked like that out of the box.
~ Jon
Somebody with a lathe and a little common sense can bore and sleeve your original master cylinder with a piece of stainless steel tubing, and it will out live you, and possibly your grandkids.
