4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
#1362955 06/01/2020 12:08 AM
Can someone tell me what the name/type of clip holds the large spring on the end of the brake and clutch pedal rods? Going back together with my new bushings and lost the clip.
Any help would be appreciated.
Thanks, Tim
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
I know what I call it, but this is a family friendly site.
Someone should be able to dig one out for you if you post in the parts wanted forum.
A C-clip of the correct size would work better than the original clip.
The FAM calls it a Pin Lock (PN 359380). Shown on Section 5, Sheet 2.00.
I'm not sure a C-clip would work, but it might. I don't recall exactly what the end of the shaft looks like, but the "Pin Lock" is weird. It's soft metal and bends pretty easily.
Classic Chevrolet has your clips. Doc
https://www.classicparts.com/1947-52-Huck-Brake-Anchor-Pin-Lock-Clip/productinfo/71%2D514/
The end of the shaft has a square cut groove cut in it just like what is called for when using a c-clip. All you need to figure out is the correct thickness and diameter of the groove to select the right c-clip.
Thank you all. I ordered new c clips. Until they arrive I have used a 7/8ā€ ā€œEā€ clip.
