| | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 52 'Bolter | | 'Bolter Joined: Jun 2013 Posts: 52 | Can someone tell me what the name/type of clip holds the large spring on the end of the brake and clutch pedal rods? Going back together with my new bushings and lost the clip.
Any help would be appreciated.
Thanks, Tim
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
| | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | I know what I call it, but this is a family friendly site. Someone should be able to dig one out for you if you post in the parts wanted forum. A C-clip of the correct size would work better than the original clip.
| | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | The FAM calls it a Pin Lock (PN 359380). Shown on Section 5, Sheet 2.00.
I'm not sure a C-clip would work, but it might. I don't recall exactly what the end of the shaft looks like, but the "Pin Lock" is weird. It's soft metal and bends pretty easily.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Classic Chevrolet has your clips. Doc
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | https://www.classicparts.com/1947-52-Huck-Brake-Anchor-Pin-Lock-Clip/productinfo/71%2D514/ | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | The FAM calls it a Pin Lock (PN 359380). Shown on Section 5, Sheet 2.00.
I'm not sure a C-clip would work, but it might. I don't recall exactly what the end of the shaft looks like, but the "Pin Lock" is weird. It's soft metal and bends pretty easily. The end of the shaft has a square cut groove cut in it just like what is called for when using a c-clip. All you need to figure out is the correct thickness and diameter of the groove to select the right c-clip.
| | | | | Joined: Jun 2013 Posts: 52 'Bolter | | 'Bolter Joined: Jun 2013 Posts: 52 | Thank you all. I ordered new c clips. Until they arrive I have used a 7/8ā āEā clip.
