| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | Does anyone know of an aftermarket emergency brake set up for the 49 GMC. I'm hoping to find a cable system that goes from the interior of the cab back to the large crossbar located under the rear of the cab | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 | The one I'm using in my '54 was pulled out of a '72 pickup. I grabbed the pedal, bracket and cable. The bracket fits pretty well between dash and firewall. Cable goes through the firewall and under the floor.
The pedal is a bit high so you have to lift your foot higher than you would on a new truck. May be a problem for tubby guys?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2017 Posts: 53 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 53 | Thanks for the idea...off to the salvage yard  | | |
