Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (TUTS 59, BLUEMEANIE, Peggy M, Waveski, 55shaker, Joe W), 516 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1350777 03/20/2020 4:36 AM
Here is one of my many projects.
Recently bought a frankenstien 1956 Chevy 6400 V8 truck.
Currently has a 1972 350 V8.
Has some customer "slipper spring" on the rear, LOL.
Found out it has the firestone RH-5 rims, bummer.
Not sure what the final plan is yet.
Considering putting my D60/D80 from my '95 Ram/Cummins into it.
More pics to follow
1956 Chevrolet 6400 V8
Here are some pics of the rear spring "modifications", under hood and test fitting a bench seat from a 2000 S10.
Rustbucket Ranch
Rustbucket Ranch
Thats a good lookin truck!
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Moderator
Moderator
2 Offline
Great looking Truck, but is cobbed up some.
Also a great way to unload it off the trailer!
Don
"The Flag Pole"
'46 2-Ton grain truck | '50 2-ton flatbed | '54 Pontiac Straight Eight | '54 Plymouth Belvidere | '70 American LaFrance pumper fire truck | '76 Triumph TR-6
I'm guessing it doesn't run judging by the wiring in the engine compartment.
Nice attachment for the exhaust pipe. wink
Is that an AD Big Bolt in the background of that one pic?
It runs, ran hot wire to dizzy off battery.
C-clamp on manifold is to hold a gasket in so it's quiet(er), passenger manifold has a hole in it I plugged with pig putty. No use spending lots of cash until I determine health and direction of project.
Guy I bought it from had a coe and a 1952, 4600.
Those are the original 265 exhaust manifolds (log type). If you decide to keep a SBC engine you should find a pair of Rams Horn manifolds and replace those...they restrict air flow.
How is the front of the rear leaf spring attached to the frame?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Mike,
All other spring mounts are good. I think someone broke a shackle or spring eye and did a farm built slipper conversion.
If I keep the sbc I was looking at center dump ram horns with generator mount. They are cheap now.
I was thinking that the slipper seems to have shortened the spring and raised the truck somewhat. Perhaps "they" were looking for "increased" load capacity...
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Not having the leaf springs attached through the eye mount seems dangerous to me!
The shaft the leafs are attached to looks like a pair of axle shafts welded together in the center...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
They are axle shafts.
Some trailer suspension designs use a free floating slipper spring similar to what this turned into. As long as the front is secure and the slipper end doesnt allow for much side to side play it should be ok. Slipper design ok, execution of this setup....less than desirable.
One problem with this is the frame has cracked where the shaft point loaded it.
Nice that it runs.
I totally understand about the C-clamp. Sounds like something I would do. thumbs_up
I think there is a U welded on under the spring to contain downward movement. Slippers are usually used to lower a vehicle or cheapen it as on a light weight trailer.
Mac :{)
Some trailer suspension designs use a free floating slipper spring similar to what this turned into. As long as the front is secure and the slipper end doesnt allow for much side to side play it should be ok. Slipper designok, execution of this setup....less than desirable.
Pulled the rear suspension assembly today. Stripping the frame of all mounts, cleaning up previous alterations. Going to wire wheel and paint.
Installing a Dana 80 and lighter spring pack.
Progress!
I bet your tractor knew it had a load when it picked that rear up... eeeek
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
Had to drop the bucket to lift it off the ground!
Explains why I didn't have as much tounge weight on the trailer as I thought.
Since the originality of this truck is already gone I don't feel bad modifying it.
While the Dana 80 is lighter than what came out it is still plenty heavy enough. Also going to remove the HydroVac system. Not sure if I'm going with a firewall mount or complete under the floor system with a m/c for a disc/drum setup.
The 2nd gen ram I'm dismembering also has a gooseneck ball mount that I'll swap over too.
It's a '95 RCLB, Cummins/NV4500 3/4 4x4.
Make sure you maintain the same MC bore size when you plan your brake system, the power brake MC's available from all the vendors is to small for the big trucks...they don't move enough fluid.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
It will have a brake system in line with modern 1 ton trucks.
The donor truck is a '95 Ram/Cummins.
First step is rear axle/springs.
The front is going to be...interesting.
I don't know how much that rear axle weights but it's more than a dressed 5.9L Cummins!
Just the rims and tires alone will be over 500 pounds and about 200 pounds wort of springs...adds up fast! The 5.9 should be in the 1000-1050 pound range...so, the rear wins! eeeek
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
Shortened the frame for a 10' flat bed.
Starting to mock up the Dana 80 and springs. These are 6" skyjacker springs that gave the Ram a 2-3" lift by replacing the factory lift blocks.
Cut the spring perches off the axle, frame narrower on old truck. Cleaned and painted all hangers from Dodge frame, leafs wider and longer. Moved axle about 4" forward from stock.
Neat. Kinda similar to what I have going on.
1957 Chevy 4400
"A Frankenstein Build"
Follow the build in Big Bolts
What's your build?
Crusing in the Passing Lane
Nice job, on my '54 GMC 620, which is a heavier truck, it was easier to cut and splice the frame to shorten it 4'.
Ed
Have front suspension stripped, axle stripped and looking into suspension options.
Update, using a radius arm kit with coilovers for the front.
Axle brackets are from ballistic fabrication, no complaints.
Radius arm kit, far from stock....quality control and customer service less than desirable. Upper shock mounts on the way from ballistic.
Steering needs to be sorted out yet, engine cross member has to be relocated for steering box.
TnDan those slipper springs you mentioned are overloads i think here in the corn belt...land of overloads...all the big trucks have em you put gun grease on so they can slide howeveri think GM aimed for leaf springs to stay dry thats what makes em strong especially when they re well arched !learned at the spring shop...fun place
In this case I was referring to the main leafs, not the overloads. The factory hangers and spring eye were cut off and turned into a slipper design using a axle shaft for frame "pad".
I grew up in the land of the "Michigan Specials", LOL.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.680s Queries: 23 (0.090s) Memory: 0.7492 MB (Peak: 0.9525 MB) Data Comp: Zlib Server Time: 2025-09-22 17:03:53 UTC
Valid HTML 5 and Valid CSS
