1 members (Ridgeback),
42
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2020 Posts: 87 'Bolter | | 'Bolter Joined: Mar 2020 Posts: 87 | Hello. I hope this is the correct place to post this. I can't figure out how to disconnect the temperature sensor line from the gauge at the dashboard. Any help would be greatly appreciated.
thanks, Mike | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hello, Mike
In each new post indicate the make, year, and model truck (and, indicate if the part/equipment is original style/type equipment). | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Mike, chances are that it does not "disconnect". Don't know what you are doing but you probably have to pull the sender and feed it and tubing thru firewall, or pull gauge and take out cluster. If that is what you are trying to do. I think if was electric, you would not ask.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
