0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1361628 05/23/2020 6:29 PM
Hello. I hope this is the correct place to post this. I can't figure out how to disconnect the temperature sensor line from the gauge at the dashboard. Any help would be greatly appreciated.
thanks,
Mike
Hello, Mike
In each new post indicate the make, year, and model truck
(and, indicate if the part/equipment is original style/type equipment).
Sir Searchalot
Sir Searchalot
Mike, chances are that it does not "disconnect". Don't know what you are doing but you probably have to pull the sender and feed it and tubing thru firewall, or pull gauge and take out cluster. If that is what you are trying to do. I think if was electric, you would not ask.
DO NOT CUT THE TUBE, it is part of a gas filled sealed system with a bulb down in the engine head...here's a picture of the gauge with bulb.
https://www.classicparts.com/1949-53-Temp-Gauge-w_-White-Needle-8-cyl/productinfo/24-703D/
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
