| | | Forums66 Topics128,125 Posts1,056,339 Members48,440 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Don’t know what to think i have a 52 Chevy truck With 235 engine i put in a electric fan with a switch so I can turn on and off anytime, I shorted out the fan wire between the grill and fender one day and smoked the relay. I replaced the relay and the toggle switch as well. so today I was running the truck and noticed with engine rpms up the fan speeds up at idle fan is off and that’s with the switch off flip the switch to off and on and fan works fine Anyone have any thoughts on this and should I just leave it? Thanks
This is no longer fun
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Sounds like the fan switch was off and the fan was off. You turned switch on and the fan came on. Sounds good to me  Can you try that explanation again? Just for me. This part: I replaced the relay and the toggle switch as well. so today I was running the truck and noticed with engine rpms up the fan speeds up at idle fan is off and that’s with the switch off flip the switch to off and on and fan works fine
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | Do you still have the belt driven fan on the motor?? If so when you rev the motor the electric fan is pin-wheeling due to the increased air flow. If this is the case I wouldn't worry about it, its not hurting anything.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Will do my best to re explain rev up the engine fan spins new relay and new toggle switch Engine at idle fan is off if I flip the toggle on fan works as it should. I didn’t hook it up with a temp sensor. Just seemed hard for me to explain issues .always appreciate the feedback
| | | | | Joined: Mar 2010 Posts: 295 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 295 | Do you still have the belt driven fan on the motor?? If so when you rev the motor the electric fan is pin-wheeling due to the increased air flow. If this is the case I wouldn't worry about it, its not hurting anything. Thanks Dave one less thing to worry about.
