5 members (msmall, GRNHydra, RaNfLaS, Shaffer's1950, Hotrod Lincoln), 88 guests, and 1 robot.
Topics128,108
Posts1,056,568
Members48,448
It's that time again for me to change out the gearbox's oil. Draining...no problem. But when it comes to pumping new oil from a gallon container into the SM420, I need to first pour the new oil into a smaller bottle that has a pumper on top. I believe that if I attach a pumper to the top of a gallon jug, it will not fit under the truck. Do some just remove the stick shift and pour the oil down into the stick shift hole?
Hope all are being safe.
Craig
Craig
H Online: Content
Remove the fill plug and pour oil into the shifter hole (slowly) until it's level with the bottom of the fill hole. Button everything up and drive!
Insomniac
Insomniac
How often are you changing the oil?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I normally change the oil every 3+ years based upon the mileage I put on the rig which is a fair amount. Thanks Jerry. I've always wanted to try that method and now since my body is starting to fight me in crawling under the turd as often as I am use to doing,,,,,
Craig
Scooting under my '48 3/4-T (pretty high) and back out are not the problems for me. It's the standing up after I get out.
7
7 Offline
I can almost sit upright under my 5700, makes it fun to inspect, repair, grease, nap, etc., I filled my SM420 through the top.
Thanks for the reply 78. I will go thru the top this time.
Craig
Insomniac
Insomniac
Thanks. Maybe I should change the oil. Not many miles since the last change, but it has been many years.
Gord 🇨🇦
Finally changed the oil and OMG! Pouring the new oil into the top is sooooooo much easier instead of via the filler plug. At least for me, it is. Thanks all for the suggestions.
Craig
