0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | hope this is a good spot. I found that the tank in my 59 is leaking. its the orig tank so it has done its job. I wonder about a new tank from one of the truck parts places or a custom aluminum tank. the price for custom will be a bit higher but may last longer. Anyone had experiance with either option? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Almost everyone that has replaced an old tank with a new one, has never complained on here.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I used Gas Tank Renu for three of my tanks: two 1954 3104 pickups and one 1954 3106 Suburban. Their pricing and service was excellent. I removed and installed the tanks. I have had no problems for about 20 years. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | If you are interested in reusing the old tank, check with a local radiator shop. Some of them will also do gas tanks. I had my 46 tank done by a local shop back in NJ. They asked if it was going to be a show truck, as there process was a little different if the truck is being graded. But for a daily driver, they cut an access hole in the tank, cleaned it, re welded the tank, and sealed it. I think it was $100 10 years ago.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mine were done in local radiator shops. | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | I didn't think of a restore. Will try some local shops. The tank looks ok except for a area on the bottom cheaper than new. Thanks | | |
