1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1360362 05/15/2020 2:43 AM
Jim C. Blue
Jim C. Blue
Nearly done!
Engine swap is complete and running. Tested with a little back and forth. Even checked the hoist and it works. Next is to bleed the brakes and go for a test drive! smile Then the lights and all the little things.
By the way, what do you think the US number for a 9700 would be? Maybe a 450? This is a "3 ton".
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
Crusing in the Passing Lane
What is the GVW?
Ed
EdPruss #1360414 05/15/2020 2:44 PM
Jim C. Blue
Jim C. Blue
17 500 lbs.
Nice truck. A 450 Series, is indeed a 3 ton.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
That is a nice truck. It looks like it is ready to take on any job, no matter how big!
1951 1 Ton Completed
Jim C. Blue
Jim C. Blue
Almost - I took it for a test drive and the clutch is slipping. The one on the other engine is no good.
Time to disconnect it again and take the old clutch off to find another.
Other than that, it works well, though I think the brakes could be better.
Replace the throwout bearing for sure and check the pilot bearing while in there.
Ed
Nice truck for sure.
Jim C. Blue
Jim C. Blue
For sure.
Thanks!
More pics.
By the way, what should I name the old beast? I already have Arrow, Vandura and Jimmy, but this doesn't have a name, like Chevy's Loadmaster.
Moderator
Moderator
2 Offline
Green Jimmy!
Don
Edit: Canadian Green leaf!
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I had a '53 GMC fire truck with 302, 6.6 gears, installed a 5831 Brownie, drove it all over, really enjoyed it.
Ed
Ed, How much overdrive would that be?
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
5831's come with .73 and .85 OD ratios, depending on following 'letter' , A, B, C, etc.
Ed
Jim C. Blue
Jim C. Blue
Drove er' home! cool
Sweet. Congrats.
Very nice truck !
Jim C. Blue
Jim C. Blue
Thanks!
After replacing/fixing a bad float, I later took er for a drive!
Jim C. Blue
Jim C. Blue
Got my alternator issue fixed. Now all ready and running great! smile
Now just a bunch of lesser but still important things, first being hooking up the wiper system, get the clearance lights working, the speedometer, adding a voltmeter and changing the one tire. Then its just a bunch of little things, though I should change the driver's side windshield some day.
