| | | Forums66 Topics128,050 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 14 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 14 | Does anyone have a source for a complete wiper switch for a 51 Chevrolet 3600? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I don't see a new "switch" to operate a vacuum motor in the aftermarket. The means a wanted ad in our classifieds, Ebay and etc. for a donor. Are you talking about what goes on the dash and has a lever handle? Is your "switch" broken or don't have anything? (BTW: It's not really a switch)
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2020 Posts: 14 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 14 | Mine is non-existent. I have seen them before (installed) and you are exactly right on what I'm looking for. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Seems like your choices are: 1. Grab the first donor "switch" you see or are offered. The knob/lever is available in the aftermarket. 2. Switch to electric wipers. 3. Change to choke type cable operated. 4. If all else fails, and you want orig looking, I have another lame idea.
