| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 3 Junior Member | | Junior Member Joined: Aug 2006 Posts: 3 | Hi, i,m a newbie here.My son and I are just starting to work on a 1970 3/4 pickup with 8 lug wheels. What I'd like to find out is what we can change on the front end ( and with what?) to get the truck in the weeds. I know that there is aftermart stuff out there, but we'd like to start with a 1/2 ton setup. We have built street rods (cars) before, this will be our first truck. I have tried to do a search here ,but could'nt come up with anything for our year truck. THANKS Joe K | | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | I would recommend going with a disc brake with drop spindle kit. upgrade to 73-87 balljoints and tie rods. then throw in drop springs while youre at it. check out http://www.earlyclassic.com/tech.aspx?category=Stance%20Photos-2 for stance photos but look around for cheaper kits. not sure about rear suspension on c20s but whether leaf or coil there are many easy options to lower it. | | | | | Joined: Aug 2006 Posts: 3 Junior Member | | Junior Member Joined: Aug 2006 Posts: 3 | Thanks for the quick reply,We're planing on using dropped spindles,but I don't quite follow what you're saying. Can we only change the ball joints and tie rods and then be able to install 1/2 ton dropped spindles or do we have to change the A arms also.Thanks Joe K | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | You can get a dropped spindle kit. Contact Speedway, they might have something.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | There actually is a kit to swap half ton spindles and disk brakes on a 3/4-ton. I saw it written up in one of the truck magazines sometime in the last couple of years.
I would expect you would just swap the complete crossmember with disks from a '72 to '87 1/2-ton and you might even find one that already has the dropped spindles.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2006 Posts: 3 Junior Member | | Junior Member Joined: Aug 2006 Posts: 3 | Well can anybody second any of the above opions? Can we only change ball joints,and add 1/2 ton spindles or can we put in a complete 1/2 ton crossmember from a later model truck??? THANKS Joe K | | | | | Joined: Jul 2006 Posts: 187 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 187 | Classic Performance Products now makes a spindle (drop or standard)for 3/4 ton trucks. It's availible with a 5 or 6 lug pattern. I have a 1963 C20 and have been researching ways to drop it and convert to discs. This seems like the simplest and economical way to git'r done | | |
