0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13599 09/10/2003 12:03 AM | Joined: Aug 2001 Posts: 12 Member | | Member Joined: Aug 2001 Posts: 12 | I would like some opinions about 15 and 16in wheels on the advanced design trucks. I am looking to buy some and not sure what size will make me the happiest? any help would be great. Thanks | | |
#13600 09/10/2003 12:06 AM | Joined: Aug 2001 Posts: 12 Member | | Member Joined: Aug 2001 Posts: 12 | i'm sorry i forgot to put original wheels. Thanks | | |
#13601 09/10/2003 12:21 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | hello there mac. i'm thinking the same as you on wheels and tires. and i'm finding that the 15 inchers might be a little less expensive as far as tires go. if you can find the steel original type wheels in 15 inch, you could probably find one of the pep boys deals like 99$ for four tires to fit! i know, i'm pretty cheap. was that your truck at barrington with the ladder racks on it? i have changed the direction of ideas on my truck. it is all stock now and a little different than when you last saw it. it will soon be on the road.[seems like i have been saying that all summer].good luck.
our garage is a non-profit organization
#13602 09/10/2003 12:40 AM | Joined: Aug 2001 Posts: 12 Member | | Member Joined: Aug 2001 Posts: 12 | No gary my truck wasn't at barrington i haven't had a chance to get it finished so it looks like next spring will be the unveiling of the improvements. I have found a nice set of 15in rims priced right that will take my original caps. what have you changed on your truck? | | |
#13603 09/10/2003 12:56 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Apparently, the GVW that is listed on the VIN tag is only applicable with the 15 inch rims, 16 inch rims for some reason resulted in a lower GVW rating. The 15 inch rims were optional, and in my experience it was hard to find 4, so I went with 16 inchers. | | |
#13604 09/10/2003 1:27 AM | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | i'm going to use steel stock type wheels with trim rings and caps, removed the dual carbs and gone back to a really good working single carb with oil bath air cleaner. i modified the t5 shifter to look like a stock 4 speed, but i might go all the way on that too and reinstall the stock 3 speed. some day i will make up my mind on it all.
#13605 09/10/2003 6:48 PM | | Anonymous Unregistered | | Anonymous Unregistered | Gary, if you decide to go back to the 3 speed and want to bail out of that T5, I'm interested in buying it. I'd like to have one to put in my '37. | | |
