5 members (Otto Skorzeny, greenie-reddy, Hush, Hotrod Lincoln, 1 invisible), 175 guests, and 2 robots.
Topics128,108
Posts1,056,227
Members48,436
Been working on installing a heidts front suspension , has any one installed one with a stabilizer bar and wondering if it’s worth buying the stabilizer bar.
1953 Chevy 1/2 ton panel truck
1957 Chevy 3200 truck
lgoodso1,
I installed a Fatman IFS on my 51-3100 and installed the stabilizer bar also. I think it was worth the extra work and money. Good luck!
Charlie
'51 3100 5-Window (Restomod in progress)
Thanks clarsen3100, been thinking about it before I finish the frame
Nice to know of your input...that's where I'm headed next.
lgoodso1...what method did you use to arch out the frame for the rack? I don't have access to a plasma cutter.
I have a plasma cutter luckily,but if I didn’t I guess would be a torch or lots of cut off wheels.
I have neither a torch nor a plasma cutter so I used an air operated sabre saw and a pack of new blades. It took a while but turned out pretty well I think.
Charlie
Well I guess I'm going to attempt an electric sabre saw and three packs of blades...to start out with!!!
A 4" grinder could make pretty quick work of that.
MNSmith
So are you saying cut out most of the notch with a cut-off disc then use a 4" grinding disc to finish shaping? Using the circumference of the grinding disc to carve out the notch?
Oh,no! Not unless you want to jerk your wrists out of their sockets.
Two straight lines and a half circle, yes? The edge of a 4" grinder will cut like a cutoff tool. It just takes a little longer because you are cutting a 1/4" swath and not an 1/8" or 1/32" swath. Then, hole saw, hog out or V cut in to your half circle. Again using the edge of the disc against the edge of the steel, carefully grind up to your line. If you sweep back and forth as you grind, you will have a smooth radius.
Same thing I do with the cutoff wheel in extremely tight corners, especially when those corners need to be square.
It all depends on what tools you have on hand. Charlie went with a saber saw and time. It worked great for him.
