8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series), 120 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
#1358750 05/05/2020 5:54 PM
rad
Offline
is a 4" drop axle the way to go or would a 3" be more drivable? any issues with a drop axle? any photos of a 4 and a 3 inch drop.....thanks
rad #1358823 05/06/2020 1:45 AM
This is my truck with a 4” drop and stock 15” wheels. I highly recommend going 3” max if you do this. I love my truck, but I think it would’ve been better to not go more than 3” around.
Double check your scrubline and talk to Sid at droppedaxle.com
Just my $0.02,
Chris
rad #1358833 05/06/2020 2:42 AM
H Online: Content
It won't hurt the axle if you drop it 3" or 4"- - - - - -just keep your toes out of the way- - - -it's heavy!
rad #1358880 05/06/2020 12:18 PM
Crusty Old Sarge
Crusty Old Sarge
I agree with Chris, 3" would be the max. I have a 4" drop from Sid, nice product, but I'm a little concerned about running 15" wheels.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
rad
Offline
Thanks, good looking truck, been in contact with sids.
rad #1358960 05/06/2020 6:14 PM
Sid is great and does great work. Good luck and keep us informed!
Chris
rad #1359025 05/07/2020 2:15 AM
I'm building a '50 3100. I've fabricated 3" blocks for the 10 bolt rear. I plan to run 20" wheels on the rear and 18" up front with drop spindles. I will admit that the stance of your truck looks fine...I wouldn't change it.
rad #1359027 05/07/2020 2:22 AM
The stance looks good but you have to look at the scrubline.
Example: looks great, but if I blow a tire, my axle is 1-2 inches off the ground. If the tire comes off the rim, my rim will not touch the ground.
I’m just saying, it’s your truck, but I don’t recommend it.
Chris
ndkid275 #1359054 05/07/2020 12:54 PM
Crusty Old Sarge
Crusty Old Sarge
Chris
I have the same issue with the scrub line, if I had to do it again I would only go to 3 inches.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
rad #1359171 05/08/2020 1:47 AM
Hind sight is always 20/20! I planned on using 16” wheels, but the 16” white walls were to much $$ for my budget.
Chris
rad #1359354 05/09/2020 2:20 PM
Crusty Old Sarge
Crusty Old Sarge
The look I was going after was 60 series tires with raised white letters (RWL). No one makes RWL tires any larger than 15' diameter, so I either change the look I want or stick with 15" tires. Currently it's being mocked up 15" BFG T/A's. Time will see.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
