4 members (ndkid275, Hush, frogfarmer, BillCollins), 101 guests, and 0 robots.
Topics128,087
Posts1,055,974
Members48,430
#1358689 05/05/2020 12:31 PM
Hey all,
How do I go about removing an engine from a big truck that has no head on it? The block is a usable full pressure 235 so I don't want to damage it. What do I hook the chain to in order to lift it out with a cherry picker? Sorry if this is a dumb question I just don't want to mess this engine up.
Thx
Utilize the head bolts/head bolt holes. Or, two bellhousing bolts and Two of the “extra” holes on the side of the block towards the front. I’ve done both ways with a chain and an engine hoist without issue.
Crusing in the Passing Lane
Use two head bolts with washers and nuts, be careful not to bend them, replace with hardware store NC bolts to protect originals. it would be best to use a spreader bar of some kind to prevent bending.
Ed
Just bolt a piece of chain snug to the top of the block, using 1/2-13 Grade 5 bolts. Use a flat washer between the chain and the top of the block to prevent putting any scars on the head gasket surface. Problem solved. I usually use a big hammer and an anvil to massage the link at the end of a lift chain into a roughly circular shape to allow the right size bolt to pass through it easily. A piece of 5/16" or maybe 3/8" chain will be plenty strong to lift any stovebolt engine.
Thank you for your responses. Hope to have it out this weekend.
