3 members (BC59, 2-Ton, Forty9),
104
Mod | | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | Trying to get ideas for a project.is there a way to put front disc brakes on a 1963 c20 or c30 front axle. | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I used the whole front suspension from an '85 when I did mine. I had to drill two holes in the frame and that was it. Everything else bolted up.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Dec 2014 Posts: 305 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 305 | Did the truck sit a the same height from the ground ? The older axle is like a drop type axle I’m not sure but I thought the newer axle is more of a straight axle | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Mine sat higher after the install, but that was because I used a 1 ton crossmember with motorhome front coils that are overkill. If I had used a c10 or c20 crossmember, it probably would've sat closer to stock.
There are some easier options with replacing the upper and lower balljoints which allows you to use a later spindle which comes with factory disc brakes. I didn't go that route because I had a free crossmember to try out.
| | | | | Joined: Dec 2019 Posts: 117 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 117 | I think we are talking apples and banana's here.. Within 29tons comment, he made mention of a "axle" that appeared to be dropped. I know that the '63-66 C-10,20 Had the independent coil spring front suspension, however I don't know if the '63 C30 had coil springs like the '64 and later. I have used the later model disk brake front suspension under '64, 66 C-10,20 trucks with no issues, a direct swap, 16 bolts, two of which have to be elongated. Not only do you get disk brakes, you also get power steering with a factory type application. Wm. | | | | | Joined: May 2020 Posts: 11 New Guy | | New Guy Joined: May 2020 Posts: 11 | Is the C30 frontend different than a C10,20? Tons of aftermarket kits available.
1963 C10 shortbed stepside
