9 members (68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M), 104 guests, and 2 robots.
Topics128,038
Posts1,055,471
Members48,424
#1351 07/11/2003 3:09 PM
Apprentice
Apprentice
Newbie here, I need to move my truck, but the gas tank has been disconnected. Probably full of gunk, rust, etc. Is there a way to hook up a plastic gas can to get some gas to the carburetor? I saw a guy that was using one with a hose stuck down it. Would I just hook it up to the line before the fuel pump, and would I have to prime it, or would the fuel pump suck out the gas? Thanks!
'54 GMC 1/2Ton
'03 Chevy Z71 Stepside
http://community.webshots.com/user/54gmc
#1352 07/11/2003 3:38 PM
Does your brakes work well?? I would say before you end up messing with all that stuff that you should tow the truck to were you need it to go. Also if you know anyone with a trailer you can ask them for help. It will be far cheaper than anything else. cool
Life isn't like a box of chocolates... it's more like a jar of Jalopenos. What you do today may burn your [censored] tomorrow.
#1353 07/11/2003 3:55 PM
magilla you need to give us some more info. Like are you moving it down the street or across town? Has it been run recently? Josh has a good point about the Brakes, do they work? Give us all the info and we will help you out as best we can.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#1354 07/11/2003 3:59 PM
If your pump is good, try using a piece of rubber hose stuck into a gas can. It should pick it up.
Fred
52 3600
69 C-10
#1355 07/11/2003 4:13 PM
Apprentice
Apprentice
Just trying to move it from the barn to the shed where my tools are. Only about 50 feet. Brakes? What brakes? Thanks Fred I will try the rubber hose trick!
'54 GMC 1/2Ton
#1356 07/11/2003 4:13 PM
I used a 6 gal. outboard motor gas can while I was cleaning, drying and sealing my truck's gas tank. I placed the gas can in the bed and ran some fuel line behind the cab to the fuel pump. After a few pumps on the priming bulb, it started and ran just fine for months. It did not siphon after shutting off the engine. I did wonder about the rubber fuel line under the cab. You could put in a piece of metal fuel line in its place.
#1357 07/11/2003 6:42 PM
I did the boat gas can trick for a few months on my '73 Scout II. Drove it around town like that, just had to remember I had a 6 gallon range. The boat tanks are safer onroad cuz they're sealed & the fitting makes hooking up a fuel line easy. For yard movement a regular gas can would work, just keep an extinguisher handy.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#1358 07/11/2003 6:49 PM
Here's another option. Pull it with your lawn mower if the ground is smooth enough. May sound silly but I have pulled mine that distance easily with a 14 HP riding mower and a short chain. You need to find a place high on the mower to connect the chain to get better traction.
Harold Wilson
41 Chevy 3/4 Ton
