6 members (jmoore, UtahYork, dt235sd, 46 Texaco, cmayna, TUTS 59), 69 guests, and 3 robots.
Topics128,203
Posts1,057,412
Members48,471
#1357859 04/30/2020 2:31 AM
Does my 1954 Chevy 235 engine hold with the oil filter canister? Can't remember..
Thanks again.
Elmo
The rule of thumb I've used for years is "5 quarts with a filter, 4 without". The problem is that the level on the dipstick will vary according to when the oil is checked. A Fram or AC canister filter will gravity drain about half a quart back into the oil pan when the vehicle is parked overnight, due to the location of the pressure control orfice in the standpipe. Checking the oil with the engine warm shortly after it's shut off will show a lower level than a "cold" check before the first startup in the morning.
C Online: Content
My notes says 6+ with a stock filter, 5 without. No matter what my notes say, I always become cautious when I get close to these numbers, so I don't over fill.
Craig
My 235 has no oil filter, and the book says 5 quarts capacity. After refilling and before I run it, I check the dipstick and it says right at full. Maybe you could do the same; check it before running and after; the difference is what the filter holds.
Lee.
1956 Chevy 3200, 235 w/3 speed
W Online: Content
The restoration guide for my '48 (not the current 261) says 5 1/2 quarts "dry." First fill after a rebuild, I guess. 5 qt for "refill."
It also says the factory installed filter option took 2 1/2 qt! Really!?
I've always figured 6 qt with new filter for the oil change.
