| | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | On my 54 Chev Panel I have original style after market wiper arms. They are bending on the smaller part of the arm nearest the blade and the blade is flopping left to right instead of staying rigged. Think that the arm spring is to strong, The blade tipped enough that it scratched the windshield . Should mention I have an electric wiper motor. is there a rigid arm and blade set up I can use ,anybody else have this problem??? Laybacklenny
layback
| | | | | Joined: Apr 2017 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2017 Posts: 47 | I replaced the arms on my 55.1 and had the same problem. It turned out that I had not seated them completely on the spindles. Not sure why that affected it. But, seating them correctly solved the problem.
1955 Chevy (1st Series) 3600
| | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | oK I will take a look at that thaks
layback
