Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (electech, 78buckshot, rfs56trk, Mike1933), 71 guests, and 4 robots.
Topics128,283
Posts1,058,519
Members48,490
#1357561 04/28/2020 12:50 PM
I have a stock 1/2 ton 58 chevy truck want to convert to disc brakes, can some of you tell me the best way to do this and best conversion kit to use?
thanks
R Online: Content
There are many options available and lots of opinions. This is the place to start to get some information. Aftermarket kits are available from numerous sources. Check some of the postings as to the reliability of the sellers, the quality of the kits, and if they have adequate installation instructions. Some kits use a booster/master under the floor, others use a firewall mounted booster/master.
On some kits the calipers will not clear the stock wheels. Some are available for 6 lug stock applications, others for 5 lug to match a late rear end.
Fred
