| | | Forums66 Topics128,283 Posts1,058,519 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 30 'Bolter | | 'Bolter Joined: May 2013 Posts: 30 | I have a stock 1/2 ton 58 chevy truck want to convert to disc brakes, can some of you tell me the best way to do this and best conversion kit to use?
thanks | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | There are many options available and lots of opinions. This is the place to start to get some information. Aftermarket kits are available from numerous sources. Check some of the postings as to the reliability of the sellers, the quality of the kits, and if they have adequate installation instructions. Some kits use a booster/master under the floor, others use a firewall mounted booster/master. On some kits the calipers will not clear the stock wheels. Some are available for 6 lug stock applications, others for 5 lug to match a late rear end. Fred
