8 members (Guitplayer, klhansen, fonz8261, cmayna, Lightholder's Dad, Hotrod Lincoln, RLB, 52Carl), 87 guests, and 5 robots.
Topics128,192
Posts1,057,229
Members48,465
Hi Just went through a bunch of parts I had bought from the filling station when I first bought the truck a year ago, and found a replacement knob for the wipers. My current one, is really beat up, like a previous owner had painted it, and removed the paint multiple times, and is rough and kind of nasty. SO, I go to put the new knob on, and it is very loose. Looking at the bottom, you can see that it's not an exact match for the original.
Before I start bending the the arms on the switch itself, any good ideas or tricks for making the new switch fit tight ?
1954 Chevy 3100
Keith, can you attached an image of the top side of both knobs?
Do you remember where you bought your new knob?
I had no problem using the knob from Classic Parts and from Jim Carter (and, Chevs of the 40s looks correct).
I bought it from the Filling station last year. Here are picts of the top.
1954 Chevy 3100
can you post the picture of the underside on the one you received that works?
1954 Chevy 3100
I'll guess that the new one is on the left (too thin a "divider"), resulting in "it is very loose".
yes, that's what I am finding.
1954 Chevy 3100
I would think if you cut a small piece off of a business card and fold it over, the to thin part of the knob, push it on the switch you probably just solved the problem.
Tommy
59 apache 1/2t
261 short stepside
Simple enough, I'll give that a try.
1954 Chevy 3100
It mostly worked. I think ill but a but of Playdoh, and try to fill in the hole a little bit
1954 Chevy 3100
Moderated by  ndkid275, Phak1
