2 members (Gray_Ghost, RoseB), 153 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#1356681 04/23/2020 1:08 AM
I have an SM420 that is seized. It had some water in it. The gears and synchros look to be in good shape but the transmission won't spin. The reverse lever mechanism moves well There is a lot of info on here and on the web about freeing up seized engines and stuck bolts but not transmissions. I did find a YouTube video about a guy who bought an SM 420 and he sprayed kerosene on the gears to make sure they were moving ok. I don't think his transmission was stuck - he just wanted to ensure movement. Any one have any suggestions as to what I can do to free up my transmission? Would filling it up with kerosene and letting it soak work? I want to get it moving them rebuild it. Thanks in adavance.
It's a small world, but I wouldn't want to paint it.
Diesel and pb blaster works. Try putting a pipe wrench on the smooth part of the input shaft not the splines and give it some hits with a hammer. Probably have to work it back and forth.
I understand that Novak Transmissions do a lot of SM420 work. Google them, they may have a customer service line that can help you.
Ed
Fill it with Evaporust and let it set overnight. Pour out the Evaporust and spray with PB Blaster or Kroil and let set overnight again. Then fill with Kerosene and start working it. A little gentle persuasion with a wooden mallet might help. Good luck.🛠
Q
Q Offline
There is a countershaft in the bottom below the main shaft,if the trans had water in it ,there is a strong possiblity that the bearings could be rusted up and siezed. If you were to get it freed up and turning,i wouldnt use it. Id take it apart and replace bearings and whet ever else it neede. If you cant get it to turn at all, tear it apart and see what whats going on in there.
Fill the case to the top with Diesel fuel and let it sit for about a week. Bolt a piece of 1/4" X 2" steel flat bar about 3 feet long onto the 4-bolt output flange with an equal amount of the bar sticking out on both sides. Use a big dead blow mallet to thump the bar back and forth in both directions until the output shaft frees up, then put the transmission in 4th. gear so the countershaft will turn and free up the bearings that support it. Once the transmission turns freely, dismantle it completely and replace all the bearings.
I'll be surprised if the gears don't whine so loudly when they run that you'll need earplugs to drive the truck.
1940 Pontiac 3sp trans from car that was always garaged BUT clothes dryer was vented into the garage it sat in for 20 years. Second pic is after it sat overnight with muriatc acid solution. Was treated not to run but to be able to disassemble. Turned and shifted fine after acid treatment but bearings sounded like it was full of gravel.
[img]https://i.postimg.cc/qg0ngJcq/1940-Pontiac-Cpe-003.jpg[/img]
[img]https://i.postimg.cc/9R47H0yF/40-Pontiac-engineand-trans-003.jpg[/img]
Evan
If the part isn't that rare, I would junk it and find a better one. As stated previously, rust pitting on the gears will make the transmission louder than normal. To bad you are on the other side of North America, I have a couple nice SM420's sitting around waiting for someone in need. If you want to free it up just for fun, filling it up with old drain oil and letting it sit for a few weeks or months will usually do the job...no heating or beating necessary.
Lots more pictures
Just go find another trans, they are plentiful, why mess with something like this. Most transmissions out of 1/2 tons show pretty minimal wear IMHO, a great place to start.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I agree with Paul...lots of us have SM-420's laying around...you can buy a good used transmission for half the cost of the Master Rebuild Kit, which doesn't include any gears.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Here's what the top looks like inside the transmission. Hard to see what lurks underneath. I already have a rebuild kit.
Inside
the top of the internals look good
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Your gears look to be in rough shape to me...the wear pattern surfaces are all pitted.
I'd look for a trans with better gears and put your new kit in that one...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Moderator
Moderator
2 Offline
I agree with some of the others advice.
Find one in better shape and go with it.
That one will just give you problems on down the road.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Yep, Make some yard art out of that one. wink
Maybe he’s just looking for a challenge to keep occupied during this mess. chug
That could be. We all need something to do. grin
I've got lots to do. LOL If I'm going to put time into this, I want to be able to use it when I'm done. I'll have to start thinking how an SM420 would look in the yard!
Looking at the pic. The big gear at the bottom is supposed to slide forward. A closer look, looks like the teeth it rides on are all chewed up and wont let it move.
This is how I recycle some of my old useable Chevy parts... We Stovebolt folks are quite creative, I am certain you can come up with something
In all seriousness, I would hunt for a better gearbox. They are out there.
Lots more pictures
Nice! The Junkyard Dog, protecting that pile of valuable parts. thumbs_up
Paul_WNC, that looks awesome. Very Creative!!
Paul, does it have a name?
BC
1960 C60 pasture art
Rusty,
Don't want to hijack your topic. Can make you a fantastic 2-fer deal on the SM420 if you can source a reasonable shipping arrangement.
The best name we have gotten for my "junkyard dog" is Gnarly, but other suggestions are welcome.
Paul
Lots more pictures
Thanks, Paul. I've got a line on a transmission locally. I can imagine shipping 135lb (that doesn't fit in a USPS flat rate box) could get expensive!
Good deal! Hope it works out.
Lots more pictures
