2 members (Southerntruck, Otto Skorzeny), 120 guests, and 2 robots.
Topics128,110
Posts1,056,242
Members48,437
#1356316 04/21/2020 12:46 AM
PA OUTLAW
PA OUTLAW
looking for a good number for 1955 chevy 3100 rear axle flange gaskets since there no good parts guys anymore !!!!!!
I believe they still sell gasket material. Wouldn't be hard to make your own gasket.
I find two axle flange gasket numbers on Napa's site.
Fel-Pro FPG 55350 - a circular gasket with 8 holes (looks like a full-floating axle flange gasket for a heavier truck)
Fel-Pro FPG 4978 - a squareish gasket with 4 holes (Likely for the axle housing to brake backing plate.)
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Some confusion going on I believe. 3100 should be 1/2 ton semi floating axle. Most 3/4 ton & larger use a full floating axle shaft that has a gasket between its flange and the bearing hub it is bolted to.
What you are calling rear axle flange, could you mean rear axle cover, round on center rear of housing?
BC
1960 C60 pasture art
Are you referring to the gasket between the wheel hub and drum 4 1/2 ID x 6 9/16 OD GM part 365673
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0510.htm
PA OUTLAW
PA OUTLAW
THANK YOU ALL!!!!!!!!. I mean the backside of the axle were the wheel studs come through the wheel studs hold this flange on. catch any leaking oil out of the wheel bearing THANK YOU!!!!!
