8 members (Gib70, 52Carl, Otto Skorzeny, Rusty Heaps, joe apple, 55shaker, Gray_Ghost, Hush),
147
0
Mod | | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | looking for a good number for 1955 chevy 3100 rear axle flange gaskets since there no good parts guys anymore !!!!!! | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | I believe they still sell gasket material. Wouldn't be hard to make your own gasket.
I find two axle flange gasket numbers on Napa's site. Fel-Pro FPG 55350 - a circular gasket with 8 holes (looks like a full-floating axle flange gasket for a heavier truck) Fel-Pro FPG 4978 - a squareish gasket with 4 holes (Likely for the axle housing to brake backing plate.)
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | | | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | looking for a good number for 1955 chevy 3100 rear axle flange gaskets since there no good parts guys anymore !!!!!! Some confusion going on I believe. 3100 should be 1/2 ton semi floating axle. Most 3/4 ton & larger use a full floating axle shaft that has a gasket between its flange and the bearing hub it is bolted to. What you are calling rear axle flange, could you mean rear axle cover, round on center rear of housing?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Sep 2017 Posts: 73 PA OUTLAW | | PA OUTLAW Joined: Sep 2017 Posts: 73 | THANK YOU ALL!!!!!!!!. I mean the backside of the axle were the wheel studs come through the wheel studs hold this flange on. catch any leaking oil out of the wheel bearing THANK YOU!!!!! | | |
