2 members (MNSmith, Lostbuthaulinass), 105 guests, and 1 robot.
Topics128,057
Posts1,055,814
#1355971 04/19/2020 1:46 AM
I dropped my oil pan so I could replace the gasket and hopefully fix some of my leaks, and I found about a 1/4 inch of fairly thick sludge and under that a thin layer of a shiny gray material that I would like to know what it is. It was between the sludge and the bottom of the oil pan and kind of looked like wet paint, and it was a little tacky like wet paint too. Anybody seen this before?
My other question is what do you put on your cork gasket and end seals. I have both RTV and type 3 brush on paste; which works better in this situation?
Thanks, Lee.
1956 Chevy 3200, 235 w/3 speed
LeeD #1356044 04/19/2020 3:08 PM
For the pan gasket I use black RTV. I glue the gasket to the sides of the block and put some at the corners where the end cork meets the block. I also put a bead along the middle of the pan lip that gets squeezed when the pan is bolted up. I also use a couple of cut off bolts in two of the hole in the block to guide the pan on during installation.
1951 1 Ton Completed
LeeD #1356053 04/19/2020 4:05 PM
LeeD,
My original 216 motor had what you described in the oil pan. Sludge and what I figured was dirt silvery muck...years & years of dust...and dirt.
Ditto on Truckernix...
It was easy on an engine stand.
-T
1950 Chevy 3100
LeeD #1356096 04/19/2020 8:07 PM
Unfortunately, mine is still in the truck, so it will be a little harder. Right now I am trying to make sure I get everything in the right order, so I need to put the cork on the engine first, and then install the end pieces, and then put up the pan. One video I watched, the installer specifically said not to put RTV on the pan side of the end gaskets; then after the pan was on, he put a bead over the end gasket on the outside to seal it. I don’t think I will be able to do that with the engine in. When I dry fitted the gaskets on the pan, I did notice a pretty good sized gap between the end gasket and the pan that will need to be filled in (unless when installed, it compresses closed). So my question is, do I put RTV on both sides of the rubber end gaskets before installing?
Lee.
LeeD #1356106 04/19/2020 9:00 PM
I had better luck sealing my ‘54 235 by putting the end pieces up in place on the block with a light coat of gasket sealer then putting the side pieces on the pan with a light coat of sealer and letting everything sit and dry for about 30 minutes. Put a dab of sealer in the corners and ease the pan up into place being very careful not to let the gaskets move. Tightened everything down and when I sold it 4 years later still no leaks. Good luck.🛠
LeeD #1356125 04/19/2020 10:00 PM
Martin,
I think you posted that several years ago. I followed it with complete success.
Yes, you can teach an old dog new tricks. Especially if the tricks/techniques are well-described and clearly explained.
LeeD #1356137 04/19/2020 10:48 PM
There is a Tech Tip I wrote up years ago.
LeeD #1356142 04/19/2020 11:03 PM
Crusing in the Passing Lane
That silvery material is probably Babbitt from being pounded out over the years.
Ed
LeeD #1356153 04/20/2020 12:24 AM
Thanks Martin, I’ll look up the tech tip too. I appreciate all the help.
Lee.
LeeD #1356166 04/20/2020 1:24 AM
I think that the sticky silvery stuff is unprocessed dinosaur snot which separated out from the original oil put in the truck on day one.
Every unmolested 216 which I have torn down has had it in the oil pan.
LeeD #1356169 04/20/2020 1:35 AM
To my knowledge, this is the first time the oil pan has been off, so it is the original dinosaur snot.
LeeD #1356172 04/20/2020 1:44 AM
Your 1956 235 engine had never been rebuilt?
It has the original rod and main bearings?
How long have you had it?
How many miles have you put on it?
How many miles on the speedometer/odometer?
What is the engine serial number that is pressed in the ledge in the block, rearward of the distributor?
LeeD #1356179 04/20/2020 2:49 AM
My father in law bought the truck in 1964, and to his knowledge, the previous owner did not go into the engine. He drove it on the farm until the mid seventies, then only seldom. The number of miles is unknown (he had a problem with the speedometer that he fixed by disconnecting it). I have had it now for about three years and have put about 2 thousand miles on it and am slowly repairing/improving items as I go ( I pulled the oil pan and pushrod cover to repair leaks and visually check what I could see). The engine sn is: 273564F56X. This is my first old Chevy pickup, so I am not an expert, but I have found very little improvements or changes on the truck (one rear brake light on left side, no seatbelts, no turn signals, etc) so no one (until me) has done much work on it.
Lee
