2 members (KEVINSKI, 1 invisible), 105 guests, and 1 robot.
Topics128,034
Posts1,055,552
#1355517 04/16/2020 2:45 PM
Trying to remove the head off my 216. It won’t budge. I am sure I’ve removed all the bolts. It’s a 47 panel with 44,000 miles. Pretty sure head has never been off. Any tricks/ideas on how to get this thing off?
1949 Chev 3800
K Online: Content
Rubber mallet should work never had one give me trouble
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Crusing in the Passing Lane
One can make an air fitting to fit in a spark plug hole, however it will only help in a cylinder with valves closed, but can rotate while applying pressure. Might have used sodium silicate for leaks. Keep trying.
Ed
Ex Hall Monitor
Ex Hall Monitor
A thin blade putty knife tapped into the space between the head & block. Those cast iron heads are heavy so have help when you lift it.
How many bolts have you removed ?? smile
If the manifolds are still attached, you could use them for a little leverage, gingerly, so as not to break them. Or stick a bolt in the manifold bolt holes.
M Online: Content
On a 216, there are bolts around the edge and one in the center. You have to pull the rocker shafts to get to it. Then go with the putty knife.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
If the engine was all together, I would put the plugs in and turn it over. I have used the manifolds for leverage.
1951 1 Ton Completed
If you look closely there should be a notch in the front left corner of the head. I thought GM put it there on purpose for this reason. You can insert a flathead screwdriver and pry.
IF you are SURE you have all the bolts removed (double check, then check again)- - - - -poke about 10 feet of 1/4 inch nylon rope into one cylinder through a spark plug hole, and gently bump the starter a couple of times. ONLY do this if you are absolutely sure you haven't missed a head bolt somewhere!
