| | | Forums66 Topics128,032 Posts1,055,519 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | Trying to remove the head off my 216. It won’t budge. I am sure I’ve removed all the bolts. It’s a 47 panel with 44,000 miles. Pretty sure head has never been off. Any tricks/ideas on how to get this thing off?
1949 Chev 3800
| | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Rubber mallet should work never had one give me trouble
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One can make an air fitting to fit in a spark plug hole, however it will only help in a cylinder with valves closed, but can rotate while applying pressure. Might have used sodium silicate for leaks. Keep trying.
Ed
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A thin blade putty knife tapped into the space between the head & block. Those cast iron heads are heavy so have help when you lift it.
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | How many bolts have you removed ??  | | | | | Joined: May 2015 Posts: 11,017 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,017 | If the manifolds are still attached, you could use them for a little leverage, gingerly, so as not to break them. Or stick a bolt in the manifold bolt holes.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | On a 216, there are bolts around the edge and one in the center. You have to pull the rocker shafts to get to it. Then go with the putty knife.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the engine was all together, I would put the plugs in and turn it over. I have used the manifolds for leverage. | | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | If you look closely there should be a notch in the front left corner of the head. I thought GM put it there on purpose for this reason. You can insert a flathead screwdriver and pry. | | | | | Joined: Feb 2004 Posts: 29,758 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,758 | IF you are SURE you have all the bolts removed (double check, then check again)- - - - -poke about 10 feet of 1/4 inch nylon rope into one cylinder through a spark plug hole, and gently bump the starter a couple of times. ONLY do this if you are absolutely sure you haven't missed a head bolt somewhere! Jerry
