2 members (Gdads51, Hotrod Lincoln), 85 guests, and 1 robot.
Topics128,039
Posts1,055,591
Hello All,
i need parts for my 1950 Chevy PU differential. How do i identify exactly which rear-end i have?
Thank you,
Start with whether your pickup is a 1/2 ton, 3/4 ton or 1 ton. The latter 2 would have 8 lug wheels.
sorry for the lack of info. Truck is a 1/2 ton, rear is 10 boltt, rims are 6 lug.
What are you needing? One other item. I'm assuming it's the original with a torque tube driveshaft. Most of the vendors sell Ring & Pinion and bearing sets. Just be sure it's for a 47-53 1/2 ton when you are looking.
Check the post for free enclosed drive line ,could be the gem you are looking for
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I was thinking about converting to disk brakes.
Originally Posted by MikeA777
I need parts for my 1950 Chevy PU differential. How do i identify exactly which rear-end i have?
Enclosed drive-shaft rear end.
Can be converted to all new parts 3.55 rear end with new parts/bearings/seals for under $1,000.
That turns this into a completely different conversation.
Can be converted to open rear end ands disk brakes with all new parts/adapters for maybe $2,000?
Thanks TC. Do you know of any write-ups about rebuilding the differential and level of difficulty? probably a hard question to answer but i thought i'd ask.
Crusing in the Passing Lane
Most car or truck service manuals, regardless of age, give detailed instructions, find one that fits your axle. Probably even some YouTube versions.
Ed
