8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#1355109 04/14/2020 12:54 PM
I
I Offline
I need to order a new water pump for my 46 gmc 1/2 but not sure what engine is in it,was told it was a 228 but starting to doubt that
ive attached a pic of the pump for reference if anyone would no which pump to order,was hoping to go for a ride this weekend
any help would be greatly appreiciated
WILLIAM A GOVE
IRR96 #1355111 04/14/2020 1:00 PM
What is the code pressed/stamped into the block at the rearward of the distributor?
That is the Engine Serial Number and it should contain the cubic inches of the engine.
If you want to ID the year of the engine, we will tell/show you the location of the date casting code (I will look for a labelled photo for the locations of codes).
Last edited by tclederman; 04/14/2020 1:03 PM. Reason: added link to images of code location - follow the thread/links
IRR96 #1355115 04/14/2020 1:14 PM
He already posted the # in another thread and it didn’t start with 228. Odd # I had never heard of. Maybe a replacement block.
Post photos of the engine and #s you find. We can help if you help us.🛠
