Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (red450IH, Peggy M, tclederman, ranchojuan), 151 guests, and 5 robots.
Topics128,289
Posts1,058,583
Members48,492
I just did a search and nothing came up but I know the subject has come up. I'm presently working on the cab of my 46 1/2 ton and took the tank out today. The bottom was half rusted out. I want to install a tank in the rear as I have seen some 1/2 tons where this was done. I was wondering if anyone has done this and has any kind of suggestions as to what tank I should get. The company that makes the tanks can go back to any chev truck or car to 1955. I want a tank that I can install in the rear between the frame rails. I installed a crossmember for the shocks and I believe I can use it to strap/bolt a tank on. Thank You. Bob T
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000660#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=005514#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=009734#000000
do a search for: .............. ''under bed''
Jim & Caroline
Thanks very much for the info.
Bob T
