10 members (Gdads51, panel fan, Lightholder's Dad, gswbbc, FAST55, 48jim1ton, frogfarmer, tclederman, Ponchogl, 1 invisible), 121 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#1355014 04/13/2020 6:09 PM
Quick question to the group. Went to start the truck and clutch is not disengaging. Linkage and clutch arm is moving. Was working when parked in the fall. any suggestions before i start pullong apart. No after market parts on the truck.
1952 Chevy 3100 1/2 Ton
ckrueger #1355015 04/13/2020 6:24 PM
Sounds like the disk may be stuck to the flywheel. I think someone here suggested a method to get it freed up, but I can't remember what it was. ohwell
ckrueger #1355017 04/13/2020 6:25 PM
that's a start. Thanks!
ckrueger #1355018 04/13/2020 6:29 PM
Just did a search and found a post string about some ways i might be able to break it loose.
ckrueger #1355020 04/13/2020 6:50 PM
You get a gold star for finding that. thumbs_up
ckrueger #1355026 04/13/2020 7:29 PM
Put it in 2nd gear. Foot on the clutch and push the starter button. Make sure your pointed in a safe direction. No longer than it’s been parked just the jolt of the engine turning will probably free it up. 🛠
ckrueger #1355033 04/13/2020 8:43 PM
ckrueger #1355201 04/14/2020 7:16 PM
Success!! Off to get my inspection.
