| | | Forums66 Topics128,181 Posts1,057,191 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 95 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 95 | I’m installing a new 12 v radio Into my 47 Chevy 3800. I have the 6 v to 12 v converter. Couple of questions: first, it calls for one connection to be to a switched 12v source and another to a constant 12 v source. Typically the switched source would be the ignition switch which of course on this truck is the original 6 volt. Do I need to add a switch on the dash for this 12 volt source, or is there a way around it? Question 2: does the on/off switch on the radio not serve the same purpose as this switched source? In other words, can I just hook up the radio to constant 12 volt and turn it off and on at the radio? Or does this delete the memory function every time I turn it on and off? Thanks much for any advice! David
1949 Chev 3800
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 6 volt accessories draw twice the current than 12 volt accessories, so no need to upgrade when going to 12 v.
Ed
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | You will lose the memory every time you turn it off.ðŸ›
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Might have better info posting in the "radio bench" forum
Ed
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The reason for the constant voltage is for memory. The switched voltage is there to turn the radio off when to go to the off position on your switched source (ignition switch). You can tie both voltage wires to the 12 source. Just remember to turn the radio off (knob) when you exit the truck.
| | | | | Joined: Jul 2000 Posts: 2,204 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,204 | You created two threads asking the same question. Not cool.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2023 Posts: 26 'Bolter | | 'Bolter Joined: May 2023 Posts: 26 | If you have a dome light in the truck, you could use a relay off that to "break" the connection to the 12 volt radio. No need to remember. or heck, use a wire off the ignition switch.
1960 Chevy C10 gasser- Rabble Rouser 1953 Harley Davidson Panhead chopper
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | AS I understand it, you have a separate power supply that will give you 12 volts from a six volt source. Normally one would connect the power supply to the ignition switch and it becomes a switched source. You don't want to leave the power supply connected to a live non switched source of six volts because it will draw current whether the radio is turned on or not. There is no solution in this case for the memory connection. | | |
