| | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | To deal with the wear on the Spring seat and rear axle housing, I cut down both faces of the spring clamp so as to make a relative snug fit on the axle housing. There is a reference to that in the shop manual for a1940 Chevy 1/2 ton.
That seems to work but I am concerned about the wear on the axle housing.
I don’t know how thick the housing is and what concerns I should have about the wear.
The warn axle housing measures about 2.635 vertical and 2.685 across at the spring seat location.
I have access to a rear axle of of a 1941 car. Would that be a suitable replacement?
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
