5 members (Charles in CA, Steelonsteel, Shaffer's1950, 52GMC35424JD, Hotrod Lincoln), 91 guests, and 3 robots.
Topics128,049
Posts1,055,665
#1353766 04/06/2020 9:06 PM
Hi, I just got my brand new (to me) 1950 pickup to fire. It has a 1955 2nd series 235 in it. Next I need fuel. I turned it over quite a bit and got it to sputter but fuel never hit the clear fuel line filter. As a source for fuel I placed a gas tank next to the fuel pump and put the fuel line in the tank to bypass everything beyond that.
My question: can I just get an inexpensive electric fuel pump to try to get this engine to run? I will rebuild the fuel pump later but want to get the engine running now.
Also, can I connect the fuel pump on the gas tank side of the existing fuel pump and leave the existing pump in place?
Thanks for any comments.
MikeA777 #1353783 04/06/2020 10:22 PM
Moderator, Electrical Bay
Hi Mike,
For over 20 years I've used an electric fuel pump on mine and I've never been happier. The old type pumps lose their diaphragms with ethanol laced gas. You can get resistant diaphragms, but the benefit to the electric pump is you don't have to crank the motor over to make it work. Here is the one I've used:
https://www.amazon.com/gp/product/B00496RE82/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1 The one I have produces 2.5 psi of fuel pressure and that's perfect for the 235. Important note: electric pumps are made to push and not to pull. Mount the pump as close to your gas tank as possible for best results.
Good luck and hope you enjoy the truck.
~ Jon
MikeA777 #1353795 04/06/2020 11:40 PM
thank you very much Jon
MikeA777 #1353801 04/07/2020 12:00 AM
Should i run the electric pump through the mechanical pump or just bypass. If i bypass, should i just plug both ends of the mechanical fuel pump and leave in place?
MikeA777 #1353807 04/07/2020 12:17 AM
I'd bypass it but I don't know if you need to plug the ends, Mike. Occasionally when the diaphragm goes bad mechanical pumps will start sucking oil in (from the inside of the engine), but if you don't see any coming out when you unhook it and run the engine, all the pump will do is suck air in and out. I ran oil filter lines through the opening where my mechanical pump used to be...
~ Jon
MikeA777 #1353822 04/07/2020 2:08 AM
A cheap new fuel pump is like 20. Ac a little more in the 40 range. Get a cheap one and see what it does.
https://www.rockauto.com/en/catalog/chevrolet,1955,truck,3.8l+235cid+l6,1326361,fuel+&+air,fuel+pump,6256
Mike
MikeA777 #1353847 04/07/2020 9:14 AM
Thanks Mike
MikeA777 #1353860 04/07/2020 12:54 PM
Crusing in the Passing Lane
I had a mechanical fuel pump start leaking fuel outside on the ground after a while when in series with an electric pump, by passed it.
Ed
MikeA777 #1353878 04/07/2020 3:31 PM
H Online: Content
If you want an "original-appearing" system, just gut out an old mechanical pump and install a sheet metal baffle where the diaphragm used to be. Then run the line from the electric pump through the check valves in the fake pump housing. The biggest risk of running electric pump output through an unmodified mechanical pump is the possibility of gas leakage into the crankcase from a ruptured diaphragm. Wire the electric pump circuit through an oil pressure sensing safety switch.
MikeA777 #1353911 04/07/2020 5:59 PM
Great input. Thanks guys
MikeA777 #1353912 04/07/2020 6:04 PM
What pressure should the fuel pressure sensing switch be rated at for a 1955 235 series 2 engine?
MikeA777 #1353914 04/07/2020 6:12 PM
2 Offline
i think there was a bunch of discussion on various threads about it
i vaguely recall numbers like 2psi is enough, 6 psi is probably a lot, more than that you probably will have a problem.
i think some folks mentioned that some new rebuild pumps deliver too much pressure
the diaphragm spring in the pump sets the pressure, you could tweek that spring in a new pump to reduce the pressure
fuel is about 3/4 the density of water
the fuel pump is about 2 ft lower than the carb
to lift the static head pressure the pump needs to generate a bit less than 0.4 PSI per foot of vertical lift
about two ft for gasoline is still under 1 PSI
conclusion 2 PSI should work in all situation
3 PSI on a new pump would probably be just right, give lots of margin for wear and various real world conditions while not being too much pressure for the carb float valve.
-s
MikeA777 #1353920 04/07/2020 6:50 PM
Page 127 of the 1955-2nd Truck Specifications Manual.3.5-4.5 psi
(save this link/document - it is very useful)
MikeA777 #1353985 04/08/2020 1:04 AM
H Online: Content
If you mean "oil pressure sensing switch", most of the combination fuel pump and idiot light switches operate at 7 PSI of OIL PRESSURE. That prevents the pump from continuing to run if the engine stalls, or in case of a rollover. Fuel pump pressure on a carbureted engine needs to be 5 PSI or less, sometimes a lot less if you're using some sort of Mickey Mouse aftermarket carb like one of the Weber types.
MikeA777 #1354019 04/08/2020 1:01 PM
When I removed the mech. fuel pump from my IHC 345 because the electric pump made it leak on the ground, I found a pressure reducer accessory, set it at 3psi, stopped flooding the carb., didn't measure the pressures.
Ed
MikeA777 #1354022 04/08/2020 1:41 PM
I'm using an electric pump with 2.5 psi. I already gave you a link to it via Amazon. 2.5 is just fine and definitely won't stress your needle/seat (which is what will cause flooding). 3 psi would be ok also. Jerry is right. In my opinion with any carb you'll be using on the 235, 2.5 or 3 psi is more than plenty.
~ Jon
MikeA777 #1354155 04/09/2020 9:41 AM
Thanks again, i ordered the pump. gonna need to wait a bit. shipping is very slow lately.
MikeA777 #1354530 04/11/2020 1:04 PM
Cruisin' in the Passing Lane
I hope you ordered a switch like Jerry mentioned or a controller. What Jerry mentioned about the crankcase filling with gas is very real. It happened to me years ago in a VW Camper. Very dangerous!
Here is a link to a controller that gives good information as to why one is needed. Fuel Pump Controller I know nothing about this product, but it does appear to be a viable option.
I would never go electric again without some type of safety mechanism.
Phillip
Former owner of a 1954 3100 w/Hydra-Matic
"To know what you know and what you do not know, that is true knowledge." - Confucius
