9 members (Tronman, TUTS 59, cmayna, Otto Skorzeny, UnclePaddy, Steelonsteel, Peggy M, 2 invisible),
78
Mod | | | Forums66 Topics128,042 Posts1,055,505 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 19 Apprentice | | Apprentice Joined: Jun 2003 Posts: 19 | Newbie here, I need to move my truck, but the gas tank has been disconnected. Probably full of gunk, rust, etc. Is there a way to hook up a plastic gas can to get some gas to the carburetor? I saw a guy that was using one with a hose stuck down it. Would I just hook it up to the line before the fuel pump, and would I have to prime it, or would the fuel pump suck out the gas? Thanks! | | | | | Joined: Jul 2003 Posts: 17 Member | | Member Joined: Jul 2003 Posts: 17 | Does your brakes work well?? I would say before you end up messing with all that stuff that you should tow the truck to were you need it to go. Also if you know anyone with a trailer you can ask them for help. It will be far cheaper than anything else.
Life isn't like a box of chocolates... it's more like a jar of Jalopenos. What you do today may burn your [censored] tomorrow.
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | magilla you need to give us some more info. Like are you moving it down the street or across town? Has it been run recently? Josh has a good point about the Brakes, do they work? Give us all the info and we will help you out as best we can.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If your pump is good, try using a piece of rubber hose stuck into a gas can. It should pick it up.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2003 Posts: 19 Apprentice | | Apprentice Joined: Jun 2003 Posts: 19 | Just trying to move it from the barn to the shed where my tools are. Only about 50 feet. Brakes? What brakes? Thanks Fred I will try the rubber hose trick! | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I used a 6 gal. outboard motor gas can while I was cleaning, drying and sealing my truck's gas tank. I placed the gas can in the bed and ran some fuel line behind the cab to the fuel pump. After a few pumps on the priming bulb, it started and ran just fine for months. It did not siphon after shutting off the engine. I did wonder about the rubber fuel line under the cab. You could put in a piece of metal fuel line in its place. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I did the boat gas can trick for a few months on my '73 Scout II. Drove it around town like that, just had to remember I had a 6 gallon range. The boat tanks are safer onroad cuz they're sealed & the fitting makes hooking up a fuel line easy. For yard movement a regular gas can would work, just keep an extinguisher handy.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Here's another option. Pull it with your lawn mower if the ground is smooth enough. May sound silly but I have pulled mine that distance easily with a 14 HP riding mower and a short chain. You need to find a place high on the mower to connect the chain to get better traction.
Harold Wilson 41 Chevy 3/4 Ton
