4 members (DaveV, moparguy, dunfire, Bills Auto Works), 66 guests, and 0 robots.
Topics128,049
Posts1,055,680
I need to find the size and location of the hole in the floorboard where the column passes through. The entire floor in my 47 3600 was replaced, and the location/size was lost.
Anyone have a measurement or two! Thanks!
You might be able to get the rubberish seal to get the correct size. Then just measure from the correct location.
Chris
OK, I just made some measurements on my cab.
The CL of the steering column opening is 12-5/8" left of center of the cowl.
The bend in the firewall is ~18-3/4 down from the top of the firewall (Measured at the location of the column opening)
The opening is semi-oval, with a ~2" wide circle at the top and a ~2-1/8" wide circle toward the bottom.
The Top of the opening is 1-3/8" above the firewall bend, and the bottom of the opening is 2-3/8" below the firewall bend.
That should get you close.
Also attached a couple of pics for you. Hope that helps
[on edit] just took look at your blog. thumbs_up
Thanks! That is what I need!
Moderated by  ndkid275, Phak1
