| | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I have 4 6V coils that I would like to bench test to see if they are good. How is this done? They are of the type that an electrolock cap goes on top of.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | If you want something more effective than a simple resistance check of the windings, chuck a distributor in a vise, and use a battery and some primary wire to connect the coil like it would be in an ignition system. Then spin the distributor with a variable-speed drill motor clamped to the oil pump drive. The high voltage lead that would normally go to the center of the distributor cap should be able to jump a 3/8"-1/2" spark to ground every time the points break if the coil is good. Some coils don't spark well without a condenser in the circuit for some reason. Jerry
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | A bench test may or may not verify whether a coil is good. Some coils which will read good while at room temperature, will not do the same once they reach operating temperature. A bench test is a good place to start, but may not pan out if the coil is on its way out. Trial and error over time will weed out the weak ones. A new coil solves all of the guess work. They are not that expensive.
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | Who sells new 6V Electrolock coils? Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | Nope- - - -that fits the top of a banjo-housing 4 cylinder Ford tractor engine. An "Electrolock" was an armored cable housing that fit the top of a mid-1930's coil on Chevy and Chrysler Corp. engines as an anti-theft device. I believe Model A Fords had the same setup. The wire from the ignition switch ran inside the armored jacket, and entered the coil from the opposite end than the high voltage tower and the primary terminal going to the distributor. Some electrolock systems had a coil with a flange that mounted through a hole in the firewall and put the whole ignition wiring setup inside the vehicle under the dash. Jerry
| | | | | Joined: May 2015 Posts: 11,266 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,266 | I believe Model A Fords had the same setup. The wire from the ignition switch ran inside the armored jacket, and entered the coil from the opposite end than the high voltage tower and the primary terminal going to the distributor. The Model A had an armored cable that ran from the ignition switch to the distributor, not to the coil. The wires to the coil were not armored. One coil primary terminal was connected directly to battery power, the other to the ignition switch, and from the ignition switch to the distributor points.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | The electrolock cap coil creates a problem for a replacement coil. One of the coils I have has 2 screws holding down the cap. I'm thinking of picking up a standard 6v coil, run the positive wire up the side of the coil and epoxy the electrolock cap on the bottom of the new coil.
Rick
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | That's one option, Rick. Another would be to make a short stepped-down adapter from aluminum for the "bottom" of a standard coil that could slip over the end of the coil and attach with a setscrew. Then the electrolock cable could be attached to the adapter with the original screws. That would be just a few minutes' work for anyone with a lathe. If you paint the adapter the same color as the coil, it would be hard to see. Jerry
| | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Who sells new 6V Electrolock coils? Jerry Oh, so I am expected to read someones ENTIRE post before I answer a question? Sheesh, tough crowd. LOL.
