3 members (Gray_Ghost, Otto Skorzeny, Joe H), 88 guests, and 4 robots.
Topics128,065
Posts1,055,865
Members48,428
#1351991 03/27/2020 10:56 PM
Question on what's acceptable cylinder wear for bore, taper, and out of round that you all go with?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
If a cylinder has over .005" taper wear, or the same amount of out-of-round, it's time to rebore. The problem is that the taper wear is not linear - - - -it happens in about the top 1 1/2" of piston travel, and the rings aren't able to flex fast enough to maintain a seal on the cylinder walls. At 2000 RPM, a ring has to expand and contract 66 times a second to stay in contact with a tapered bore. Metal fatigue sets in, and the rings lose their tension and quit sealing in a very short time. A straight-wall overbored cylinder that's properly honed for quick ring seating eliminates the ring flex.
