7 members (J Lucas, Otto Skorzeny, asilverblazer, tclederman, Hotrod Lincoln, klhansen, 1 invisible),
135
Mod | | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | My 1955 Chevy Second Series 3600 has, and always has had, 7.00x15 tires. Last night while looking through the Shop Manual, at the back it lists tires and inflation, but does not list that tire size. The smallest is 6.70x15. What should I have? Can I put the 6.70x15 on my current rims? Thanks,Scott | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I went to chevy.oldcarmaunualproject.com and looked up the inflation charts and weight charts. The 3600 tuck had 15-6 and 15-8 tires listed. The 3100's used the 6.70-15 though. I'm guessing that the 7.00-15 were installed out of convenience more than anything else. I'm in the same boat with my 54 3600. It came with 7.00-15's also. I've upgraded to modern 16" rims on mine though. I'm still debating on whether or not to go with Bias or Radial tires. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The tires for the 3/4 ton aren't listed by size other than rim size. The "15-6" and "15-8" designations are actually rim diameter and ply rating. BTW, if you're considering radials, make sure to get the tube type if you plant to keep the 2 peice wheels. If you want to go tubeless, consider swapping to a single peice wheel.
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The 15-6 and 15-8 confused me, when everything else was listed in tire size. Thanks for clearing that up for me too. | | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | I realize this was started by me years ago, but is there a Radial replacement for the 7.00-15 tires? I'd be keeping the split rims. I'm not really liking the idea of radials, but can't seem to find a set of Bias-Ply that are reasonable. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Example 7.00-17 or 700-17 means the rim is 17 inch under the lip The diameter of the hole in the tire rubber is 17 inches The 7.00 or 700 means the wall of the tire is 7 inches With these numbers you now know the diameter of the tire The plies is also in the tire spec and listed on the rubber 8 ply is a common work tire good for 2500-3000 lbs per tire with appropriate pressure I’ve also seen 10 ply And sometimes modern tires list “ply equivalent” Because the tires aren’t made the same anymore internally but they want you to know easily what to compare it to in the old books
I usually stick to max load specification anyway and ignore the ply or equivalent ply numbers
For my 1 ton I made sure to get a load rating over 3000 lbs as I fill that thing up till the auxiliary springs are nearly bottomed out sometimes
Check out Sampson brand tires if you want actual tube type non radial for split rims and actual work load rated capacities
| | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | In 2011 I bought 2 new 7.00-15 Load Range D (8 ply rating) nylon cord bias ply tires from a local tire shop. The were Power King brand. I don’t know where you can buy them or if they are still available.
Professional Novice
| | | | | Joined: Feb 2002 Posts: 39 'Bolter | | 'Bolter Joined: Feb 2002 Posts: 39 | I have found those on-line and I'd rather buy those. I most likely will thanks to the stimulus check. I was hoping there might be a used, cheaper Radial option on facebook. Now, can I get away with a narrower tire on that rim? Perhaps a 6.70-15? Maybe a 6.50-15? | | | | | Joined: Nov 2004 Posts: 2,423 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,423 | I was under the impression that tubes cannot be used with radials.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | I was under the impression that tubes cannot be used with radials.
John Close, you can't use bias tire tubes. Gotta be radial tubes. RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My Suburban has 16" Cooper radial truck tires with tubes and little red-plastic stem protectors to prevent/lessen "chafing" against the slightly rusted tube holes in the rims.
I have only put about 1,000 miles a year on them since around 2004.
It needed new "shoes" for its 50th birthday party. | | |
