Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 31 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#1347122 02/19/2020 4:06 AM
Hi. I’m just checking to see if anyone has heard of a vendor that is reproducing the rubber floor mat for the Task Force trucks with an SM-420 four speed. I’ve found plenty that carry one for the column shift.
Thank you,
LJ
LAJones48 #1347194 02/19/2020 8:50 PM
I would think they are the same with the option of cutting out the hole for the floor shifter ,they may have a marked outline on the mat for the trucks that have a floor shift to make it easy but you would have to ask that question to the vendor .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1347217 02/20/2020 1:15 AM
When I first bought this truck in 1984, I found a mat at Golden State Pickup Parts. It did have pre punched holes for different options. Now all I can find say they are specifically for column shift trucks. I think the floor hump is different.
LAJones48 #1347225 02/20/2020 1:42 AM
That is a good question, I'm shopping for a floor mat for my '58 with high hump trans cover. 'Classic Parts' brand new catalog shows one but if you try to order it online, only the column shift mat is available. LMC offers a molded industrial polyvinyl mat that covers the whole floor for $179.95. It's supposed to last longer than rubber and I'm leaning that way.
LAJones48 #1347233 02/20/2020 2:45 AM
I too have considered the LMC mat for my '59 3800, but have no idea how it will fit. If you decide to try it, please post your opinions about the fit and appearance.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
LAJones48 #1351261 03/23/2020 4:49 AM
LAJones48 #1351308 03/23/2020 6:51 PM
Thank you. I’ll try them
LJ
LAJones48 #1354693 04/12/2020 1:35 AM
speaking of the rubber mats, what is used to keep them from sliding around on the steel floor ?
woof359 Family 1952 3100 5 Window
LAJones48 #1354703 04/12/2020 2:53 AM
There are some studs riveted to the toeboard up near the vertical part of the firewall, that the floor mats slip over. They have a ridge at the top to keep the mat on.
Pic of the passenger side ones.
On edit, this is on an AD. I assume the TaskForce trucks are similar.
oldbolter #1358986 05/06/2020 9:31 PM
I purchased the LMC polyvinyl floor mat for a 1958 Chevy 32 w/high hump transmission cover. I was impressed with the material and the quality. They fold the mat like a blanket into squares for shipping and there are some heavy creases that didn't come out after unfolded for 48 hours at 72 degrees as instructed. I placed a towel over the creases and used a household steam iron and the creases came out easily. I'd use much caution if you did this.
"Some trimming may be necessary" is quite an understatement. It is molded pretty well to the hump and the seat mounting area, but all borders must be trimmed. All holes in the mat for pedals, shifter and all mounting bolts for seat and gas tank must be cut. I spent a good 10 hours on all of this.
I very much recommend the mat, just be ready for the effort.
LAJones48 #1359029 05/07/2020 2:37 AM
Thank you. I’ll check it out
Moderated by  ndkid275, Phak1
