| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | I'm getting ready to rebuild an SM465 I recently bought for my C60. I've been doing some research to learn about the rebuild on these. I am concerned with getting that spanner nut torqued down on the output shaft. Is there a size designation for these or is it a special GM tool? I sure like the right tool when possible. At any rate is there a part number or size I should be looking for? Thanks. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | If you look at the last page for the transmission chapter in the service manual, there will be a listing of the special tools needed. There will be a part number for the original Ken-tool. Google is your friend. | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks I finally found a manual. I've never worked on one of these before. | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | I just now discovered that my trans uses a hex nut. I feel relieved. After looking at my trans I understand why the book mentions the spanner type for 4wd units.
