Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (sron48, J Lucas, Hotrod Lincoln, klhansen, Peggy M, 1 invisible), 453 guests, and 1 robot.
Topics126,777
Posts1,039,267
Members48,100
Most Online2,175
Jul 21st, 2025
Moderated
Moderated
I am hoping to match a 4 speed transmission (casting 590470) that came out a truck with an open driveshaft to a 1946 1/2 ton pickup with a torque tube driveshaft.
Do I need some sort of adapter on the rear of the transmission? The transmission has 10 spline shaft and the torque tube has 17 spline shaft.
I am not familiar with the 4 speed you have so this is my best guess. The only 4 speed that I know of that is available with an adapter for a torque tube is an SM420. This transmission is about two inches longer then the original 1946 transmissions, and would require shortening the torque tube or moving the engine. Not a good option. The usual approach is to use an open drive shaft. This would require using an open drive shaft differential pumpkin from a 54-62 half ton.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.113s Queries: 14 (0.074s) Memory: 0.5948 MB (Peak: 0.6261 MB) Data Comp: Zlib Server Time: 2025-09-22 04:29:24 UTC
Valid HTML 5 and Valid CSS
