1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
Page 2 of 2 1 2
ASU Offline
I did not use the carrier bearing, and got anew driveshaft made. About $250 IIRC. You will also have to make sure a scrap yard find has the correct yokes for the ujoint.
Jon
Crusing in the Passing Lane
It is always best to have a new driveshaft made, it is not worth dealing with questionable driveshaft histories, unless one is able to verify fitups and history. Driveshafts can only be shortened, not lethened.
Ed
EdPruss #1358551 05/04/2020 5:40 PM
Any driveline shop worth it's salt can build you a longer driveshaft, but it takes welding your yokes to a new continuous piece of tubing, not splicing on to the existing. Kind of expensive, but if your yokes are good, it may be a little cheaper than having them build a complete new driveshaft.
I checked out Denny's driveshaft and looks like they have great reviews. Gonna do some measuring and probably order one from them.
Wes
Page 2 of 2 1 2
