9 members (klhansen, Southerntruck, Barry Martak, TexasJim50, Gdads51, J Lucas, Stovebolt48, Hotrod Lincoln, tclederman),
120
Mod | | | Forums66 Topics128,089 Posts1,056,422 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | The trans in my 65 is needing work. I went ahead and bought a 465 trans from salvage that I think was out of a 68 C70. Anyhow it came with what I assume is a mechanical clutch linkage bell housing with the fork coming out of of the left side. My bell housing is the hydraulic clutch type. However the opening in my current bell housing is the same diameter as the retainer on the 465 it slides right in. I can use it but I've always wanted to go with a mechanical clutch. What parts would I need and what can be bought new? If I need used parts does anyone know of a source? I'm not finding any 60's era trucks in salvage around here. Is the pedal and pedal assembly the same? I see some new parts like the rod and cross shaft new but will the same ones that fit the half ton 65's fit my C60? Thanks. | | | | | Joined: May 2017 Posts: 330 'Bolter | | 'Bolter Joined: May 2017 Posts: 330 | You could find a 1/2 or 3/4 ton with the mechanical stuff in it to compare brackets, rods, and links with what you have. I don't know what would fit but I would bet some of it would. You might only have to make something longer or shorter to fit your truck. Lots of stuff on the big trucks is several years behind the smaller stuff design-wise.
Mac :{)
1962 K10 short step side, much modified for rally 1969 T50 fire truck, almost nos, needs a few things
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | no idea on the 65 but on the 55-59 Chevys, the clutch linkage is the same from 1/2 ton all the way up to 2 ton (C60). | | | | | Joined: Jun 2007 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 85 | Thanks for the response guys. I'll see where I can find some half tons or any others to look at. A parts book and parts numbers would be great to find as well. Thinking about it I will probably just put it back together as it is for now so it will be ready for harvest in June. I put new clutch in with cylinder and line in 2015 so everything is in good shape. I've got the mechanical type bell housing so I can change things over when time allows. I guess I have no good reason for needing to go to mechanical I just prefer them. | | |
