0 members (),
115
Mod | | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 20 Grease Junkie | | Grease Junkie Joined: Feb 2020 Posts: 20 | In a previous post I reported a problem with contact between the oil pump pick up tube and #5 connecting rod in my 57 chevy 235. Turned out the tube was bent. I dropped the bottom plate to remove the bent pipe and the gasket was damaged in the process. Now, it appears, GM #838451 has been discontinued and none of the local dealers or parts stores still stock it. My online search so far is also coming up empty. From reviewing old threads on this subject, this has been a problem for a number of years now. Has anyone out there found a source for this elusive part, outside of what comes with a new pump or rebuild kit?
Some of the old posts suggest making a DIY gasket from a piece of paper, being careful to find paper as close as possible to .009" thick. Is this a safe option?
1949 3600 w/ 57 235 | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | The pump will never miss it if the gasket isn't included in the assembly. I've run plenty of oil pumps without a gasket between the pump housing and the base. Just be sure there's a little vertical clearance between the gears and the base plate to allow for expansion due to heat. If you choose to make a gasket, I'd suggest using a piece of soft aluminum like a Coke can rather than paper. You really don't want a blowout with full oil pressure against the gasket. Jerry
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Send me a PM. I probably have one you can have. I almost never throw anything out from the gasket kits, even if I don't use it.
Mike
| | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | You can buy a GM NOS oil pump gasket GM # 838451 PIC https://i.postimg.cc/mkQTns22/Oil-Pump-Gasket-GM-838451.jpgAvailabe @ Friesen's Chevrolet Sutton , Nebraska phone : 402 - 773 - 5538 Friesen's has ( 1 ) in stock Dan's GM Obsolete Chinook , Montana phone : 406 - 357 - 2615 Dan's has ( 8 ) in stock George '54 3600
| | | | | Joined: Feb 2020 Posts: 20 Grease Junkie | | Grease Junkie Joined: Feb 2020 Posts: 20 | Thanks much for the responses. Just got off the phone with Dan's GM Obsolete and have the gasket on its way.
Steve
1949 3600 w/ 57 235 | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The late pumps I've examined show the pump gears below and almost flush with the end of the gear cavity, and a .009" gasket (added to the negative clearance) is wayyy too thick unless your gears extend above the gear cavity. Correct gear end play against the cover (with the gasket compressed): .002"-.0025". | | | | | Joined: Feb 2020 Posts: 20 Grease Junkie | | Grease Junkie Joined: Feb 2020 Posts: 20 | The late pumps I've examined show the pump gears below and almost flush with the end of the gear cavity, and a .009" gasket (added to the negative clearance) is wayyy too thick unless your gears extend above the gear cavity. Correct gear end play against the cover (with the gasket compressed): .002"-.0025". Thanks for the heads-up! I'll be checking clearances while I wait for the stock gasket to arrive. The existing pump did have a gasket but it must have been installed with sealant, so no way to know how thick it was. If I need a thinner gasket I can at least use the stock gasket as a template. If the gears are indeed recessed in the pump body, what kind of sealant should I use to install without any gasket? Thanks in advance Steve
1949 3600 w/ 57 235 | | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | NO SEALANT! If necessary, use a piece of plate glass and 1000 grit wet/dry sandpaper and water to polish the mating surfaces of the pump housing and the base plate. I still haven't figured out the necessity for a gasket on a part that seals perfectly well without one, and if there's a seep leak, the oil just drops right back into the oil pan. If the pump has such a low volume output it can't can't compensate for a few drops of leakage, it doesn't need to be installed on the engine. Jerry
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | The gasket is important for the hydraulic lifter folks. The idea was to keep air from entering through the mating surface and contributing to aeration of the oil and air in the lifters. Same for using just a bit of thread lock on the pickup tube. Mechanical lifter motors, this is not so much of an issue. That being said, panic is quite right about using a gasket or not. Some pumps came with gaskets and some did not so the end clearances will be different between the two types of pumps. Thus, installing a gasket on a pump that did not have one originally might not be the best move. Conversely, not using one on a pump that did is also probably not the right move. And then there is the quandary of installing a thicker gasket where a thinner gasket had been previously installed.
With the cost of machine work and parts for these motors, it seems to me that maybe the better play would be to source a new pump and pickup rather then risk a potential failure of the motor down the road. I see NOS or RNOS pumps on ebay all the time for less then 100.
Mike
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Even though the specified clearance range is very small, any more room allows pressure to bleed away under the gears rather than being forced into the high pressure port. This will not affect maximum pressure above cruising speed, but it's a substantial loss at idle when oil volume is minimal. | | | | | Joined: Feb 2020 Posts: 20 Grease Junkie | | Grease Junkie Joined: Feb 2020 Posts: 20 | Thanks to all for some really good advice. Not sure if my pump is original or a replacement but I'm pretty much stuck with it. Whoever reassembled the engine rounded off the retainer lock nut, I guess by using the wrong size wrench. I'd have to pull the crank to get enough room to deal with that situation. So, I'll be measuring carefully and shooting for .002" final clearance.
Steve
